05.31.2007, 06:42 PM
I guess you could start with the obvious. Plug a servo (steering maybe?) into the throttle channel and see if you get it to turn. If so, then the signal is OK.
I know the transmitter in the picture was part of the package, but do you know if it is Futaba based? Some RTRs can come with the electronics from other manufacturers - they just put their label on it. Either way, you could try reversing the throttle channel and give it a go.
I assume you are trying to calibrate it to the ESC according to the ESC's manual...
nastety92
05.31.2007, 07:29 PM
Brian thank you very much for the help. Yes I'm going through the setup process per the manual. I can see now what needs to be done. I talked to Mike for a little while and he was helping me out on the phone. The problem is that when it tries to program the neutral setting it keeps rejecting it. I'm going to play with it a little more then try my receiver and transmitter from my stock e-maxx.
I also had my esc wiring plugged in backwards. Brown wire should of been out not in. I learn as I go, I'm sure these are newbie mistakes.
Nick
nastety92
05.31.2007, 08:58 PM
The truck finally lives. I got the stock traxxas receiver to work. The truck is pretty faster, wheelies on comand. The first time I went anywhere near full throttle it flipped on its lid and slid down the street about 100 feet, I was chasing after it in my slippers.
Thanks for the help getting it running, I appreciate it.
More pics and video to come soon.
Nick
pb4ugo
05.31.2007, 10:38 PM
Just so everybody knows, Airtronics builds the radios for Associated.
