silentbob343
06.15.2007, 01:14 AM
Originally Posted by ncalenda
I have the Futaba 3PM-FM radio and my wire broke on my receiver, so I need a new one.
I currently have the Futaba R153F 3-Channel FM 75MHz, should I just replace it with the same one? Or, is there another one that is a better option.
resolder the wire.
if it broke at the box and you can't solder close enough, open the box and solder the wire.
You can even buy a new receiver wire if you don't want a soldered wire.
http://www2.towerhobbies.com/cgi-bin...?&I=LXERH8&P=7
ncalenda
Need for Speed
ncalenda's Avatar
06.15.2007, 01:25 AM
Good idea, it ripped off at the top of the Antenna Tube, so I would be able to solder it. Once I solder it, should I shrink wrap it? I lost the part that hangs from the top, so how long of wire should I solder on? I'm assuming a longer wire would be better.
  Send a message via AIM to ncalenda
benjakas
06.15.2007, 01:41 AM
No, the longer wire is not better. An antenna has to be in tune with the wavelength of the signal received.
