IBJAMMIN
IBJAMMIN's Avatar
06.25.2007, 11:05 PM
Originally Posted by nitro28
Are you guys using a spacer between the motor and the rc-monster mount? When I put mine in it looked like the pinion would nearly have to be pushed up against the front of the motor to make contact with the spur.
Flip the pinion over and mount it so the teeth are facing the motor mount. I run a diferent mount bolted to the diff mount yours replaces the diff mount so the motor is closer to the spur. :)
