Serum
Serum's Avatar
06.26.2007, 12:48 PM
we all know the answer..
loose contact..
can you ask him for a picture for my gallery?
othello
HV basher
06.26.2007, 01:02 PM
Seems you had the same experience? Loose contact. Was this the answer from schulzes support when you send yours in? What happened?
Sorry ... can't remember exactly how many stories i already red about smoked schulzes.
About the pic ... I'll ask another member in the german forum who seems to be in touch with him
man...........
man........... - 06.26.2007, 01:06 PM
i just got talked into buying a neu motor for my schulze controller, is there anything that can be done to prevent premature failure i'm afraid to use it
othello
HV basher
06.26.2007, 01:53 PM
Well
. Make sure every electric connection is properly insulated and cannot easely come loose
. Try to mount your ESC so that shocks are not directly transfered to your ESC
. on your maiden run constantly check the temperature of your ESC and your motor ... If the ESC/Motor gets to hot ... change your gearing accordingly
. If your ESC/motor still gets to hot you can mount a small fan or heat sink on your esc/motor
. Check the temperature of your connectors too (Batteries -> ESC)
A monitoring device like the eagletree Micropower could be usefull to check your AMP requirements and see if you're overstressing your ESC. But this is not absolutely necessary. It can help understanding that every small change can affect Amp draw more or less seriously (Mounting bigger tyres for example has a huge impact).
but _paralyzed_ dont worry too much ... I think if you do not overstress your ESC it wont happen ... The circumstances as to why that happened in this video are not obvious and it shouldn't happen normaly ... There are other threads about smoked Mamba Maxxes, MGMs and so on ...
othello
HV basher
06.26.2007, 02:16 PM
Those are pics from where the ESC was mounted in his truck after this incident
Sorry no pics of the ESC yet
