gizzmo79
06.26.2007, 07:42 PM
i have a heatsink attached to it, but this dosent provide any cooling to the topp of it. The rest of it is cool, its only onthe top where the cabels to the battery are that its hot.
Sorry the bad english i'm from Norway
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.26.2007, 07:52 PM
Yes, the Quark dissipates a lot of heat compared to other controllers, to add to that it's thermal design sucks, mostly from the internal thermal pads, which are mediocre, at best.
So you say the battery cable side? I don't know why that side would be overly hot, usually the motor taps on the pcb are very hot on the Quark.
The best way to cool the Quark is to do the internal mod to it like many here have done. The internal pad is replaced with a thicker one, and is thermal epoxied on. Then use a decent heatsink on it.
BrianG has said he thinks the engineers have sacrificed efficiency with the controller for better firmware (in it's own way i guess), like being cog free, and very smooth in driving.
There really is no 'ultimate truck controller' out there, we are going to have to wait for the MMM, and Tekin to see what they have with their up coming controllers.
zeropointbug
Z-Pinch racer
06.26.2007, 09:22 PM
:dft012:
Although, after the big "Quark thread" on here, a couple of us got some extra capacitors to put on our esc's, AAngel made a small cap bank for his MM, he says it stays very cool, and hardly cogs after he did it. Extra caps are going to help the Quark somewhat too, but it doesn't seem to make as big a difference as with the MM.
