06.26.2007, 10:45 PM
Since you say you will be running two packs, I assume you are going with a pack on each side? If that is the case, I would get two 2s packs and put them in series.
As far as capacity, it depends what you plan to do. For racing, you want the least amount of weight possible while choosing a battery that will supply the power you need for as long as you need for the heats/mains. For bashing, weight isn't as big a concern.
If you want to spend the bucks for some nice packs, get the flightpowers or similar quality. They will be light yet pack the punch you need. If cost is a bigger concern, maybe a pair of Maxamps 2s2p 8Ah packs would work well. You'll get lots of runtime (about 30-40 minutes at a guess).
Another thing to keep in mind is the battery C rating. You want to pick a pack that has a C rating high enough to cope with the current you'll be pulling. I always choose a pack that can put out about 25-50% more current than you'll need. This will keep them from getting too hot since they won't be working as hard.
BTW: You can simply continue your other thread for the same vehicle without having to create a new one for a different sub-topic...
