08.29.2007, 11:07 PM
The general conscensus(sp?) is that the neu motors work with the mm if the gearing is lower and the mm is setup a specific way. It would be nice if someone could post their esc setting and then the rest of us idiots could copy it! IIRC the start power had to be at the highest setting and the punch control disabled. This got the motor spinning from stop and I think the timing worked better set low. Not sure if anyone adjusted the throttle curve or not. Working with my sh***y memory is not easy, but I would love to try a neu motor.
