GriffinRU
09.02.2007, 08:51 AM
I will say something strange have you thought about using 2-3 eagletree's in parallel?
Should work fine and later you can play with data from both to figure out total draw.
lutach
lutach's Avatar
09.02.2007, 05:06 PM
Ok, here is the situation. The motor that I was using for some reason got demagnetized. I will restart the comparisons with a Aveox 1412 motor. I don't know that Kv of the motor, but I will only be running 11.1V and 14.8V. My daughter just came back from PA and I'll wait until school starts to do this.
GriffinRU
09.02.2007, 05:22 PM
1412/1 - Kv 2932
1412/1.5 - Kv 1945
1412/2 - Kv 1466
1412/3 - Kv 1011
1412/4 -Kv 729
1412/8 -Kv 528.8
1412/16 - Kv 183
Data from www.aveox.com
With 11-15V it would be easy to find out which one you have.
lutach
lutach's Avatar
09.02.2007, 09:05 PM
It seems to be the 1412/1. It took me a while to go from motor to motor, but the one without the label seemed to balloon the tires more then the other Aveox's I have. The other ones are the 1412/1.5 and the 1412/3.
nieles
nieles's Avatar
09.07.2007, 10:20 AM
could you zoom in at a few high amp peaks so we can see the voltage drop better. thanks
  Send a message via MSN to nieles
lutach
lutach's Avatar
09.07.2007, 10:56 AM
nielis,
Here is just the voltage curve.
Name:	Mr. C's MBX5T, MGM TMM 16016-3s, Aveox 1412 1y, 2 5000mAh 7.4V (Wired in series for 14.8V)b.jpg
nieles
nieles's Avatar
09.07.2007, 11:00 AM
these cells are very good, around 3,6v @100 amps.
is the price in the flightpower range or lower?
lutach
lutach's Avatar
09.07.2007, 11:14 AM
This are the Kong Power packs. I'm trying to become the distributor here in the US, but I heard other companies have tried as well without success. I know one distributor sell the 2200mAh packs really cheap, but they don't carry the 5000mAh packs. You can buy it directly from Kong Power's website. I heard a few people are having a lot of trouble with their TP and FP. The Kong Power packs won't puff, you can go as low as 2.2v per cell and they do run cooler.
09.07.2007, 12:07 PM
How cheap is really cheap? Do you have a link, as I would like to see the sizes of the 2200 cells.
lutach
lutach's Avatar
09.07.2007, 02:03 PM
www.kongpower.com
mkrusedc
NeuMaxx
mkrusedc's Avatar
09.07.2007, 12:21 PM
This may seem like a basic question, but what does the different amp ratings mean?
TMM6018 vs TMM16018?
Thanks
lutach
lutach's Avatar
09.07.2007, 02:05 PM
Thanks
It should means the 16018 can put out 160A and the 6018 only 60A.
lutach
lutach's Avatar
09.07.2007, 02:08 PM
Ran the truck with the MM and it seemed to have performed better on 4S than with 3S. Power to spare. It wasn't as smooth as the MGM, but it seemed to deliver a tad bit of more power. Ran it for around 8 minutes and the MM was warm and so was the batteries.
Name:	Mr. C's MBX5T, MM, Aveox 1412 1y, 2 5000mAh 7.4V (Wired in series for 14.8V).jpg
lutach
lutach's Avatar
09.23.2007, 02:33 PM
Some pictures of the MBX5T.
Name:	Mr.C MBX5T-a.jpg
ID:	3280   Click image for larger version
Name:	Mr.C MBX5T-b.jpg
ID:	3281   Click image for larger version
Name:	Mr.C MBX5T-c.jpg
lutach
lutach's Avatar
09.23.2007, 02:34 PM
One more.
Name:	Mr.C MBX5T-d.jpg
