crazyjr
crazyjr's Avatar
08.31.2007, 01:13 AM
Mine runs great, I am running a VXL stampede with stock 3500 motor, stock gearing and both 2s and 3s 5000 mah Lipo's. The take off is about the same as the mamba's, the brakes are awsome. If you want a little, use a little, need a lot, lock them up. Even with the stock traxxas radio, control is awsome. I run it a solid 20 minutes today and the motor was 120* and the esc was 109*
I did notice one thing, if you double pumped the brakes at under 5 mph(roughly), it will jump into reverse
08.31.2007, 10:45 AM
Those are good temps, your batteries may be able to handle the load better than my 3s 4000, however mine got hot (190+) on 2s with a 5000 20c battery. Maybe I had a bad esc??!!
I noticed the reverse thing too, only when I was playing in my office, not outside at speed.
lutach
lutach's Avatar
08.31.2007, 11:05 AM
I had my VXL-3S set up without reverse. Traxxas should have made a few options on the strength of the brake. You have to be a brain surgeon to get a smooth braking action going. Try your trucks with forward/brake only and see how the braking action is and post the results here.
