lutach
lutach's Avatar
09.05.2007, 12:15 PM
Today I drove the truck and it was a good run. I ran it just over 7 minutes with my other 2200mAh, 11.1V packs in parallel, MGM TMM 160-3s and the Aveox 1412/1y. The MGM didn't get warm at all and the lipos were the same way (Impressive), but the 1412 was a bit hot, not too hot because I could keep my finger on it for over 10 seconds. The real story here are this lipos. This tiny packs deliver some serious power. After the run I put them on the charger and it showed 11.64V and I only put 1806mAh back in them. The only problem is they are only available in 2200Mah sizes. The factory told me they are working on a larger capacity. The graph from the DPR-II-150 shows a max AMPs of 164.34A, but there were a few over 100A+ bursts. The pack didn't get warm at all. The MGM has to be the smoothest controller so far from all the controllers I've been using on this truck. I only wish my Quark 125B didn't burn. I will continue tomorrow, but with the MM and same lipos.
Name:	Mr. C's MBX5T, MGM TMM 16016-3s, Aveox 1412 1y, 2 2200mAh 11.1V (4400mAh).jpg
lxmuff
lxmuff's Avatar
09.05.2007, 01:10 PM
In your data, it looks like you stopped a couple of times. Was that on purpose or did the controller stop?
lutach
lutach's Avatar
09.05.2007, 01:26 PM
It was actually to see if everything was OK temps wise, specially for the batteries. I didn't know how they would do.
Finnster
KillaHurtz
Finnster's Avatar
09.05.2007, 02:12 PM
What batts are those? Those are impressive #'s.
I really like the sound of the MGM controllers the more I hear about them.
lutach
lutach's Avatar
09.05.2007, 02:27 PM
I will actually start distributing those lipos after I'm done with the abuse. I'll try to get around 50 cycles on them before I make a decision. I'm still trying to figure out a name for them or I should just go as is without a brand name and just offer great cells and put at nice price and warranty on them. They come in 3 voltage range: 7.4, 11.1 and 14.8V. I don't want to jump on this right away and have problems later on like some other companies are having.
lxmuff
lxmuff's Avatar
09.05.2007, 02:57 PM
Thanks for following up with this thread and the data. For the kinda work that I do.... "you are just another opinion without data".
lutach
lutach's Avatar
09.06.2007, 10:40 AM
Just came back from running the truck with the MM. Well let me start by saying the weather was a bit cooler than yesterday's run with the MGM. It is around 74 degrees and everything was just perfect. I ran the truck for over 10 minutes and stopped for a while, because of a spectator LOL. The MM was warm and the batteries was around 90 degrees. Now I said everything was just perfect and that "was" is due to the darn DPR-II-150 not recording the run at all. Came home, plugged it to the USB port, opened the program and got slammed with a "No mission data available". I wouldn't mind if the truck wasn't performing good, but it was just too good of a test that this had to happened. The Aveox took a beating and it was hot after the run. This truck did some nice wheelies, full throttle and hard braking. Tomorrow I will run it again and hope that the DPR will record some data.
