lxmuff
lxmuff's Avatar
09.05.2007, 01:10 PM
In your data, it looks like you stopped a couple of times. Was that on purpose or did the controller stop?
lutach
lutach's Avatar
09.05.2007, 01:26 PM
It was actually to see if everything was OK temps wise, specially for the batteries. I didn't know how they would do.
Finnster
KillaHurtz
Finnster's Avatar
09.05.2007, 02:12 PM
What batts are those? Those are impressive #'s.
I really like the sound of the MGM controllers the more I hear about them.
lutach
lutach's Avatar
09.05.2007, 02:27 PM
I will actually start distributing those lipos after I'm done with the abuse. I'll try to get around 50 cycles on them before I make a decision. I'm still trying to figure out a name for them or I should just go as is without a brand name and just offer great cells and put at nice price and warranty on them. They come in 3 voltage range: 7.4, 11.1 and 14.8V. I don't want to jump on this right away and have problems later on like some other companies are having.
lxmuff
lxmuff's Avatar
09.05.2007, 02:57 PM
Thanks for following up with this thread and the data. For the kinda work that I do.... "you are just another opinion without data".
lutach
lutach's Avatar
09.06.2007, 10:40 AM
Just came back from running the truck with the MM. Well let me start by saying the weather was a bit cooler than yesterday's run with the MGM. It is around 74 degrees and everything was just perfect. I ran the truck for over 10 minutes and stopped for a while, because of a spectator LOL. The MM was warm and the batteries was around 90 degrees. Now I said everything was just perfect and that "was" is due to the darn DPR-II-150 not recording the run at all. Came home, plugged it to the USB port, opened the program and got slammed with a "No mission data available". I wouldn't mind if the truck wasn't performing good, but it was just too good of a test that this had to happened. The Aveox took a beating and it was hot after the run. This truck did some nice wheelies, full throttle and hard braking. Tomorrow I will run it again and hope that the DPR will record some data.
The 5000mAh packs are here!!!!
lutach
lutach's Avatar
The 5000mAh packs are here!!!! - 09.06.2007, 01:54 PM
Good news folks. The 5000mAh packs are here (2 7.4V and 2 11.1V) and so is a really nice small 1600mAh pack that was sent with the big packs for me to try out in my Xray M18. I soldered some deans before I went to get my daughter from school and I guess one of the plugs went bad. It kink of freaked me out as it read 7.65v when I plugged to my AF109 and then it went down fast. I got my alligator clips out and found out it was the deans and not the pack. The 5000mAh packs come with 10GA wires and they are very good quality wires too. I will run the 2 7.4v tomorrow with the MGM 16016-3s and hopefully the DPR will record some data.
