09.16.2007, 05:39 AM
I also noticed that the top plate is adjustable to allow the bulkheads to sit father apart. I am guessing this is to allow use of the plastic kyosho spur gears.
FG101C
09.16.2007, 11:08 AM
Did'nt think about that pimp. The only problem I have with the motor mount plate is it's thick. The 18 tooth pinion I have on there barely fits without hitting the motor mount screws, don't think a 20 tooth will work. But it fast enough with the 18 tooth. Ballons the tires all the way down the street.
