09.25.2007, 10:51 AM
I got the Mini-LST ball diffs, Solid center spool and GPM pinion today and I'm breaking them in. So far they are better then the viscous. The ESC is working great with the Hyperion motor. I will run it some more to see how the diffs behave.
Good luck man, I hope that it works for you. I tried the center spool and grenaded both diffs in two runs. I eventually removed it and tried a MIP ctr ball diff, worked much better that way, and helped keep the wear on the ft and rr diffs down. I tried all of the different pinion gears and none worked as well as the viscous setup.
lutach
lutach's Avatar
09.25.2007, 03:28 PM
The ball diffs with the center spool is working great so far. I'm finally having a blast. I just have to do some final adjusting of the ball diffs.
lutach
lutach's Avatar
09.26.2007, 01:44 PM
I found the problem with my Mini LST. The diff input shaft is bent and it making the pinion eat the diff ring. It is only in the front tho. I will do some up grading on my Mini LST. I wanted to test the ESC with the 11.1V 1600mAh KongPower battery pack, but that have to wait now.
