mkrusedc
NeuMaxx
mkrusedc's Avatar
09.25.2007, 11:41 PM
You are using a plastic pinion?
VintageMA
VintageMA's Avatar
09.25.2007, 11:46 PM
If the pinion is plastic and the screw is metal, you might have a hard time there. Might be time to look for a metal pinion.
Does the motor shaft have a flat spot on it? If not you could create a flat spot on the shaft with a dremel where the screw touches it - that would help.
Then you could use locktite on the end of the screw that meets the flat metal shaft of the motor. Tighten the screw down good and let the locktite set on the metal to metal contact point for a day and give it a try.
“Everyone has a right to be stupid; some people just abuse the privilege.”
jhautz
jhautz's Avatar
09.26.2007, 12:02 AM
If the screw hole hole on your plastic pinion is worn out you could try drilling another hole in the pinion smaller than the grub screw and just force threading the screw into the new hole. Being plastic the screw should just form its own threads. Although in the long run you probably should look ionto getting a metal pinion. Plastic isnt going to hold up to long. Even the aluminum pinions dont last very long.
EDIT: Just read your most recent post. Same still goes for the new hole idea though.
to make it...
or break it...
Silent...But Deadly
bb16
09.26.2007, 12:24 AM
May try that, but you reminded me of something i wonder if something called thread rebuilder would work.
09.26.2007, 12:53 AM
JB Weld sticks metal to plastic nicely. Probably not a good idea if you ever want to remove it though. Try a flatspot on the shaft and some ca on the threads of the set screw. Not too much, a little should help the screw stay in there.
bb16
09.26.2007, 12:01 AM
Its an adapter inside a nitro clutch bell so I can run my LST clutch bell on my LST the adapter is plastic but the gears are metal.
