Manslaughter
09.29.2007, 01:50 AM
Yea, I have a 220 watt weller soldering gun that i used, I think that should be enough. I have tried it on all the torque settings, and its currently on the lowest one.
Also thanks for any help.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.29.2007, 01:59 AM
Try running it on NiMH mode, just to see if that works?
But, I also think it might be your radio... I was using stock radio and i had the weirdest glitches ever, and like you said, I could recreate them.
Gallagher
10.13.2007, 09:09 PM
Try to use race mode without safe mode.
I solve the same kind of problem with this setup.
It could be some kind of glitch to cause the problem.
However, I burn my esc with wrong polarity after I found the solution.
Pretty sad.
