What do you think of this setup for e-revo?
09.30.2007, 08:23 PM
With the 2 speed; yes. Having two gears will work the motor less. You should use an XL for a single speed just because of the greater start power needed.
Visit BrianG's homepage!
Find all posts by BrianG
2
david lamontagn
09.30.2007, 08:29 PM
OK so i'll give it a try. The only thing is the 2 speed, don't know if the gear will hold the shift with brushless power
I'll loose the slipper...........
david lamontagn
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
