david lamontagn
09.30.2007, 08:43 PM
That's for this reason Brian that i've thin to use the Robinson hardened gear set, the pin for the second speed is plant right into the steel. Much more solid, no??
09.30.2007, 08:56 PM
My friend had a bl revo running a 8l on 3s and the 2 speed. It ran fine, so the 12l on 4s should be ok. Go up to the xl if you want to go single speed.
