jnev
jnev's Avatar
10.02.2007, 12:16 AM
The only weak spot I've seen is the little pins that hold the gears to the shafts inside. But a little modding and the use of Jato pins instead fixed that and haven't had issues since.
I was trying to do this, but I realized that the drill bits I have are not hard enough to drill through it... Are there any hardened drill bits that you would recommend for drilling through the shaft(s)?
Finnster
KillaHurtz
Finnster's Avatar
10.02.2007, 12:22 PM
If you need drill bits, you can order bits from Mc Master Carr, harbor frieght or someother if your LHS (local hardware :) )doesn't have a good selection.
MMC has a very good and detailed selection menu where it details the diff bits for the diff apps. They have fractional sizes, number ga sizes, metric, etc.
RCShocker
RC Monster
10.02.2007, 06:15 PM
Darn Finnster, I was looking forward to your comparison of the transmission's
You are NOT running the E-Maxx tranny the second time around on your Revo, are you?
