Procharged5.0
Procharged5.0's Avatar
10.05.2007, 01:57 PM
No problems with a NEU 1515 on the FLM case, but thats the largest motor I've put on. The NEU is 39mm in dia. Maybe 42 w/cooling fins.
10.05.2007, 04:21 PM
The KB motor will need a custom mount plate to replace the stock emaxx plate. The mount holes are m4 thread and 30mm apart. The motor is 45 mm diameter(duh) and the smallest gearing chice will be 52 spur and an 18 pinion. With the gearing and tire size on the LST I figured an 18 or 20 should get me to 40mph or so.
