VintageMA
VintageMA's Avatar
10.11.2007, 10:36 PM
Nice job - I remember that you and I had pretty much the same setup going (motor, esc, 3S batteries). How are your temps doing?
I have been running 17/46 and the speed is pretty potent. I have the 18 and 20 pinions and would like to try them.
My esc temps have been around 140*, but I was using the MM BEC with 3S so that could explain. Just got the CC-BEC so waiting to get a chance to run it again to see temp are better.
Peak power has been 722 watts at a peak current of 72Amps.
Also, how are those tires doing. How is the ballooning at top speeds? I have the Dirt Hawgs and they balloon pretty bad at speed, I'd really like to find something that can handle the speed better.
“Everyone has a right to be stupid; some people just abuse the privilege.”
jhautz
jhautz's Avatar
10.11.2007, 11:20 PM
I havent really run it yet. I just finished it on Monday so hopefully this weekend it will get a good test run. I'm pretty sure it shoud be OK on temps. I was running my Lightning Staduim 10 on this motor w/ a MM and 4s a123 for a while and temps were fine. I was using a UBEC on the MM and have a UBEC set up on the crt.5 too.
I also run these tires on the LS10 and they actually handle pretty well so I bought a set for the crt.5 too. Balooning isnt to bad, Traxxas sells these for use i=on the VXL Bandit which can run 70mph, so 45 should be no big deal for them. I'll let you know how it runs after I get it out and give it a workout.
How does your Hacker 8L do on temps?
to make it...
or break it...
Silent...But Deadly
VintageMA
VintageMA's Avatar
10.12.2007, 08:47 AM
Thx for the info. One more question - do the Traxxas tire mount properly to the stock CRT.5 wheels or did you have to get a different wheel.
I've been very happy with the temps running 17/46. I was bashing it hard for about 20 minutes and the temps never got above 115* while running. When I would stop and let it rest for a minute the temp would climb up a bit to about 125-130*, but that's all. I'm using the temp probe from the React mounted in the heatsink right above the end-bell. A temp gun confirms that the probe is accurate to within a few degrees at the hottest point on the motor.
jhautz
jhautz's Avatar
10.12.2007, 07:43 PM
Yes they. Mount right on the stock wheels. Just get the bandit rear 2.2 tires. The rustler/jato 2.8 tires don't fit.
to make it...
or break it...
Silent...But Deadly
