Thunderbruiser
Thunderbruiser's Avatar
10.12.2007, 01:37 PM
also i agree it may not be the best setup...and if you add another it won't go faster it'll just accelerate better.. for the cost of the novak you can get a better system and have a truely fast truck
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
JThiessen
JThiessen's Avatar
10.12.2007, 03:12 PM
Are you going to run 4WD? If not, you'll want to stretch that chassis as long as you can.
Wouldnt you also want to eliminate the tranny and get as close to direct drive as you can? (assuming of course that you have optimized your motor for the weight and drive ratio). Maybe one of the outrunner brushless motors might work well in this particular appication (long discussion on those in the temporary forum).
Also, I would guess that the G3 chassis would almost be quite heavy for drag racing.
Drag racing is all about the amount of potential energy you can store, and the ability to completely release it by the end of the track.
