Finnster
KillaHurtz
Finnster's Avatar
10.18.2007, 08:58 AM
I've the finned version and realy don't fit.
I've e-mail Mike and he can make one to fit.
Hmm that's strange, mine is finned and works well. What pinion?
One thing I did was have all the bolts in loose (rear support and motor) set the gear mesh, then tighten everything.
Depending on how you twist the motor it may not fit correctly if you try to add brace in afterwards.
david lamontagn
10.18.2007, 10:57 AM
The rear suport on the revo mount is made for feigao smooth or finned can, and the Neu finned can is larger than Feigao, so it's impossible that anyone of the both rear support fit.
I've tried of many way to fit it but nothing to do. The motor is bolt right at his place and the smaler rear support slot don't align with the 2 holes in the motor mount.
I realy don't know how you can fit the rear suport with the Neu finned motor, but something should "pryied" very badly
Plus, the half moon shape in the rear mount realy don't match the motor can shape.
