sikeston34m
sikeston34m's Avatar
Smile 10.18.2007, 05:56 PM
Yes Zero, The one of the new 4025 Scorpion Outrunners is what I have my eyes on. Before I actually place the order, I still need to decide which one. These are the ones that have the new endbell bearing to keep things in line.
Alot of quality engineering there I think.
For you guys looking at cheap ways to charge A123's, one the 4 Series setup ONLY, go to Walmart and get one of those "cheap" digital Auto chargers. They have a charge voltage cutoff of 14.5 volts. This is perfect for 4 Series A123.
Then if you're charge 4S1P, set it for 10 amps. If you're charging 4S2P, you can set it for 20 amps. Either way, you will be charged and ready to go again in right at 11 minutes! Check into it.
