10.20.2007, 10:36 PM
The only thing I can think of is to set the EPA and trim to 0 and try to recalibrate the radio, but the chances of that being the problem is slim. Dumb question, but do you have the throttle cable plugged into the receiver the right way?
lutach
lutach's Avatar
10.20.2007, 10:48 PM
The setting on the radios was all good. I have everything connected the right way. I just put my Schulze 18.97 and it is running fine with the JR radio. I will contact Ing. Grisa Dvorsky to see if he can upgrade the 16016 to the newer versions.
pb4ugo
10.31.2007, 06:20 PM
He told me it could not be. There are hardware differences. He could only update the software.
lutach
lutach's Avatar
10.31.2007, 08:06 PM
The problem might be something else. I spoke with one of his employee and I will have to send it in.
ncalenda
Need for Speed
ncalenda's Avatar
10.31.2007, 01:04 PM
I have a dumb question, how do you know which is the correct way? I have a new received, and I don't see any marks telling me which way neg should be. Is there common knowledge, like, do they want the signal wire on the inside?
  Send a message via AIM to ncalenda
david lamontagn
10.31.2007, 03:32 PM
Normaly, the ground (black wire) is the pin far right, when you look your reciever in face.
