lutach
lutach's Avatar
10.27.2007, 07:03 PM
Originally Posted by Aragon View Post
That's great. Are you able to see the direction of current flow in the graph? The DPR records in both directions, so that spike could be current drawn from the battery or current drawn by the battery...
The spike was upwards so it actually went to the battery.
Aragon
10.27.2007, 07:39 PM
Excellent! Do you plan to test it in driving? Braking at varying levels downhill would be interesting to see.
How much does the voltage spike?
lutach
lutach's Avatar
10.27.2007, 09:31 PM
Today I actually got everything back together. The rear diff on the BPP let go and I had an issue with my Aveox in the MBX5T. So I will get some data on Monday if the weather is good. I didn't notice what + volts the spikes were. I just noticed they were there. I'm going to look in my previous data to see if it is there and I'll "prt sc" on a close up.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.27.2007, 11:07 PM
So, you are seeing what I saw then, as far as a voltage spike to the battery? I saw, IIRC, about 0.25 - 0.5 volts spike, so even a little potential over the battery packs voltage will result in decent current levels going into the pack.
lutach
lutach's Avatar
10.27.2007, 11:45 PM
I will have to agree. The spikes seems like 0.25-0.5. I also noticed a sound coming from the ESC (Schulze 18.97). I listened closely to figure out where it was coming from and it was from the capacitors. It sounded almost like when you take a picture and the capacitor inside the camera recharges after the flash, but it was more like a blow-off valve. I have to see if the same spikes appers with the MM. If so, I think setting a little drag brake might throw some charge back into the pack.
