wheeldean
wheeldean's Avatar
11.02.2007, 10:03 PM
Must of next day the tekno kit, mine wont be here til next week. Cant wait to see some of your pics.
11.02.2007, 11:07 PM
Yep, I have a tekno kit coming too, the price was too good to pass up, plus I found a revo roller for 155 with a ton of spares. I still need to go thru it and makes sure it is in good shape! Will be interesting to see how well the clutch adapter thingy works! I am thinking of going with a 15l on 5s, or maybe aveox will get my 2000kv motor back to me in time. I have a quark 80 air esc to use as brakes are not a concern.
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
This link will explain alot about diff fluids and diffs.... enjoy
http://www.rc-monster.com/forum/showthread.php?t=5050
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
Matthew_Armeni
Matthew_Armeni's Avatar
11.03.2007, 12:18 AM
Wow, it was awesome, until I stripped a spur doing a wall ride . I have the 3.3 chassis I got from Arct1k but no brace, and I had the slipper set maybe a little too tight to bash with (I race with it tight). My mesh may have been just a tad tight too, maybe. Also, it didn't switch gears, I think it was stuck in second. Well I'm going to replace that spur and I got a body to paint, but I'll post some pics first. My Mamba and TrueRC battery were both cool to touch but the fiego was getting hot already (only ran for about 5 min neighbor saw me do a wallride perfect then said I should do it some more, another neighbor comes out.... you get the idea). The clutch felt really good, smooth starts. Theres a little more deadband at the beginning of the throttle as opposed to a direct drive setup but I think it feels good. Something I was thinking about the clutch, it should lower the peak amp draw because it is easier to get the car moving. Anyway, any questions?
  Send a message via AIM to Matthew_Armeni
Matthew_Armeni
11.03.2007, 12:37 AM
Some stuff I got
The TeknoRC kit as it come out of the box
Battery Tray
Bottom part of motor mount
Mount standoffs
Matthew_Armeni
11.03.2007, 12:46 AM
ESC plate
Tranny mount for plate
The elec clutch, you don't have to use an e-clip, a 3mm screw and washer work too
The motor mount, the slot is so you can get to the setscrew
And something cool about the motor mount (If I mounted mine in the low position the motor would have just barely rubbed the rear arm, but that's because I am using the RC-Monster heatsink, the higher position fits fine, and it you run a neu there's no interference, I can't give up the extra cooling for lower cg)
And because I live in San Diego, where Tekno is based, regular mail only takes a day to deliever
Matthew_Armeni
11.03.2007, 12:57 AM
And finally, a complete shot, after my spur gear incident
11.03.2007, 02:05 AM
So... How is it? Does it run well, any quirks?
