Matthew_Armeni
Matthew_Armeni's Avatar
11.03.2007, 12:18 AM
Wow, it was awesome, until I stripped a spur doing a wall ride . I have the 3.3 chassis I got from Arct1k but no brace, and I had the slipper set maybe a little too tight to bash with (I race with it tight). My mesh may have been just a tad tight too, maybe. Also, it didn't switch gears, I think it was stuck in second. Well I'm going to replace that spur and I got a body to paint, but I'll post some pics first. My Mamba and TrueRC battery were both cool to touch but the fiego was getting hot already (only ran for about 5 min neighbor saw me do a wallride perfect then said I should do it some more, another neighbor comes out.... you get the idea). The clutch felt really good, smooth starts. Theres a little more deadband at the beginning of the throttle as opposed to a direct drive setup but I think it feels good. Something I was thinking about the clutch, it should lower the peak amp draw because it is easier to get the car moving. Anyway, any questions?
  Send a message via AIM to Matthew_Armeni
Matthew_Armeni
11.03.2007, 12:37 AM
Some stuff I got
The TeknoRC kit as it come out of the box
Battery Tray
Bottom part of motor mount
Mount standoffs
Matthew_Armeni
11.03.2007, 12:46 AM
ESC plate
Tranny mount for plate
The elec clutch, you don't have to use an e-clip, a 3mm screw and washer work too
The motor mount, the slot is so you can get to the setscrew
And something cool about the motor mount (If I mounted mine in the low position the motor would have just barely rubbed the rear arm, but that's because I am using the RC-Monster heatsink, the higher position fits fine, and it you run a neu there's no interference, I can't give up the extra cooling for lower cg)
And because I live in San Diego, where Tekno is based, regular mail only takes a day to deliever
Matthew_Armeni
11.03.2007, 12:57 AM
And finally, a complete shot, after my spur gear incident
11.03.2007, 02:05 AM
So... How is it? Does it run well, any quirks?
Matthew_Armeni
11.03.2007, 02:50 AM
Yeah ,it runs really well, great actually. The quirks I had were my fault, I was in a rush to assemble it and did not properly shim the clutch, it's fine now, and the slipper was a little tight, fixed that as well. Painting the body now, everything will be ready to race for tomorrow
riceman
RC-Monster Gold
riceman's Avatar
11.03.2007, 01:05 PM
Looks great Matt - You racing Barona today? I was going to try to make it out today for the kick off of their Saturday points series. Too many new projects popping up due to the wind/firestorm. Hope to race with you soon.
