Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
11.10.2007, 07:55 PM
Actually I am running an aveox 36/30/1.5, very similar to a 2000kv L can feigao. I am running it on 5s lipo and am geared 15/40. I can go lower to a 14t clutchbell, but that is it. Other than that I can put the close ratio gearset in to lower the top speed. I will try it out again tonight and see hoow it runs. I have a feeling that the talons that I have on it are worn out and have too much sidewall play. This is causing some interesting high speed wandering/flips!
I also agree that being skeptic is ok, but until someone has tried out this setup for themselves it is hard to pass final judgement on it. It may be different but it seems to work well. I am just having trouble remembering that I do not have reverse!
Matthew_Armeni
Matthew_Armeni's Avatar
11.10.2007, 08:40 PM
Huh, I got the motors mixed up. Maybe if you drop down to a 4S pack, then your gearing may feel a bit better, and help out with the overheating clutch. Good luck!
  Send a message via AIM to Matthew_Armeni
