zeropointbug
Z-Pinch racer
zeropointbug's Avatar
11.19.2007, 01:55 AM
Yeah, I found that the 7XL has loads (s**t loads) of power on 5s2p, but it also takes s**t loads (huge s**t loads) of power from the battery. Drawing 135amps consistently.
11.19.2007, 11:26 AM
ooooh! you cussssssssssseeeeeeeeeeddddddd iiiiimmm teeeeellllllling!
Finnster
KillaHurtz
Finnster's Avatar
11.19.2007, 12:21 PM
I too have the TrueRC 4K cells, but in an 8K pack. I think 4K is too small. I think the motor you are looking at is a bit small too. A 1940 at a min. A 1940/7 on 4S would be great. The MM may or may not like 5S, I wouldn't bank the setup on it.
You should be getting ~120A peaks, which is alot for a 40A continuous cell. Driving is very peaky, and I think you will overdraw and heat up the cells. If you really want low weight you got to pony up a bit. I'd at least get the 5K cells if you are determined to stay cheap and 1P
zeropointbug
Z-Pinch racer
11.19.2007, 08:49 PM
You little tattle tailer!!
11.19.2007, 09:28 PM
hahahaa
11.19.2007, 10:41 PM
Actually, no one tattled, but I saw the response and just HAD to edit it for you. No extra charge.
zeropointbug
Z-Pinch racer
11.19.2007, 11:38 PM
Geez Brian, you always got my back!
