a 9L won't run too much hotter than an XL, all the feigaos run hot no matter what.
yeah im probably gonna try the 7XL and MM combo, i've never use a fan before...what fan did you use and whats the best way to wire it up. thanks
I can't recommend a specific fan, but the way I wire mine up is to use a "Y" connector to split the external BEC and fan, to go into the "battery" slot in the receiver. It has to be a 5V fan though I think.
