11.30.2007, 03:18 PM
ESC:Quark 125b (will need the heat modification sooner or later after you start running it), or MGM 160/18.
Motor: 10lb truck, hmm,.... 9XL.
Lipo: Anything 5s? I would say maxamps, trakpower, trueRC- all the well known brands basically. Look for the voltage you want to run, a minimum of 4000mah, and 20-25c ideally. Obviously, the better the specs, the higher the price (true rc does 8000mah 10c packs that would be good; so long as the batteries can cope with the amp draw of the motor, you will be fine).
Whats your budget for motor and esc? there are much more efficient motors available than the feigaos, but with a lower kv rating like the 9xl it shouldnt be in danger of running too hot, especially with a fairly average weight truck- not a 13lb lump thankfully.
rckcrwlr
Where are the Rocks????
rckcrwlr's Avatar
11.30.2007, 04:00 PM
I can't spend a ton of money...this is going to be a backyard basher...would it make more sense to go with a 10xl with 5s to keep things cool?
Here is my problem...I have gone the wrong direction too much with this truck by purchasing the wrong esc and a 9L before I really got on this site. I now have a new 9L sitting...I want to do the right thing, only once.
I was looking at the quark monster pro esc in the store, is that what you are referring to or is there another Quark 125?
Soooooo Confused.
Thanks for helping.
John
Bought my Wife a Rock Garden :027:
rckcrwlr
rckcrwlr's Avatar
11.30.2007, 05:31 PM
With these numbers, do you think the 10xl would be the way to go???
Vehicle Weight (approx): 10
Desired top speed in MPH: 40
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.6956521739130434
Additional Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 14
Battery Voltage: 21
Tire Diameter (inches): 7
Total Ratio: 18.42857 : 1
Tire Circumference: 21.991 inches (558.575 mm)
Required Motor RPM: 35397.099 RPM
Required Motor KV: 1685.576 RPM/V
Good Motor Choices:
BK Wanderer 11 XL (kv=1516)
BK Wanderer 10 XL (kv=1668)
BK Wanderer 9 XL (kv=1853)
Better Motor Choices: No motors of this class fit the parameters you entered.
Best Motor Choices:
Neu 1515 2.5d (kv=1700)
Neu 1515 1.5y (kv=1500)
Neu 1512 1.5y (kv=1900)
Neu 1512 3d (kv=1700)
LMT 1940/10 (kv=1588)
LMT 1940/9 (kv=1742)
Neu 1521 1.5d (kv=1860)
Neu 1521 1y (kv=1577)
LMT 1950/9 (kv=1452)
LMT 1950/8 (kv=1634)
LMT 1950/7 (kv=1867)
