rckcrwlr
Where are the Rocks????
rckcrwlr's Avatar
11.30.2007, 11:04 PM
This is my recommendation to you:
ESC: MGM 16018 (I say this ESC over the 125b just because of the heat problem that it tends to have)
BL Motor: Feigao 9XL or 10XL; would you prefer more speed, heat, and less run time or less speed, less heat, and longer run time? (If you can swing it, go for a Neu 1515/2.5d; 1700KV)
LiPo Cells: TrueRC 5s2p 8000mAH pack will work great (There are better out there, but they also come at a price. Many people have had great luck with these TrueRC packs, including me )
Will I have heat problems with the Quark???? I was going to buy the heat sink too. Would it be better to just get the 16018????
Is it easy to program? The other ESC I had was a pain.
When you give me the options for the motor...what are the differences in speed, heat and run time? I can't swing the Neu...
Thanks for the input...
Bought my Wife a Rock Garden :027:
rckcrwlr
rckcrwlr's Avatar
11.30.2007, 11:13 PM
It looks like with everything else the same that here is what I will get:
11xl = 40 mph
10xl = 45 mph
9xl = 50 mph
Which is going to run the coolest???? the difference of 5 mph is not going to matter to me. And that is with my current 14/46 gearing. I could change that to get more speed. Knowing that which would be better for me to bash around with...
