Grind a Neu...
Patrick
12.14.2007, 12:10 AM
I ground the shaft on mine. I never use loctite, and the pinion doesn't come loose. I don't grind the last 1mm or 2, so if the pinion does start to come loose it shouldn't be able to slide past the ridge at the end of the shaft.
Patrick
Find all posts by Patrick
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
