rchippie
rchippie's Avatar
12.17.2007, 08:25 PM
I was going to buy this chassis today. But the tech at ofna told me you can only use a standerd sevo & not the mini servos. I have 2 mini servos all ready & did not want to buy another servo just to use this extended chassis.
REAL MEN RUN BRUSHLESS
GO-RIDE.com
12.17.2007, 10:22 PM
I couldn't be happier with my RCM Extended Chassis Kit. It instantly was more stable than the old stocker, but initially turned a bit slower. I fixed this by reducing the stock 2* toe out to 0* toe. Now it turns great on our tight indoor 10th scale track. I mostly run 2.2 truck tires which give a really balanced look to the 40mm longer chassis.
E-8ight - Tekin RX8 2000kv/4S
12.18.2007, 09:25 AM
Hi,
Just did a quick search - you could still use your existing servos and pic up a couple of these.
Cheers
http://www.alignrcusa.com/index.php?...roducts_id=613
http://www.espritmodel.com/browsepro...apter-Kit.HTML
