12.19.2007, 07:35 AM
That is a known fault with the plastic caps - They flex too much and can break the top of the shick off - You can rebuild them with the aliminium caps and plumbers tape which stops most issues.
This pede has Traxxas Aliminium big Bores all round so the only issue I get is bent shafts...
I popped in some stiffer blue springs in the back last night too after the photo was taken...
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
12.19.2007, 04:52 PM
Thanks. I might give those a try. And that idea with the fuel tubing would probably work too. I doubt it's worth fixing the stock ones now as they have popped so many times the threads not looking too good.
Excellent Body!!!!
stampedeproject
stampedeproject's Avatar
Excellent Body!!!! - 12.24.2007, 03:10 PM
Glad you joined the club! The best body you can ever put on a bashing Stampede period. Mine is still going strong.
