wallot
wallot's Avatar
12.26.2007, 04:46 PM
I use simple L shaped aluminum profile to mount my MGM with one side and bottom heatsink touching the mount. as long as ESC gets some airflow it will be ok. And I use 5.5mm bulletconnectors as bigger=better :)
soldering is easy - just tin the wire, tin the connector and while the tin is melted just put the wire inside the connector and hold it for a second to cool off.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
