12.28.2007, 10:45 AM
So, what motor mount did you use?
myndseye
myndseye's Avatar
12.28.2007, 12:08 PM
I used the Kyosho mount from Mike. I will have you guys know that when I ran the 1527 1D on 6s, it was serious overkill. This chassis did not present enough load to generate any heat in the motor, and contrary to what most may think, and in my experience, I feared hurting the motor that way. I have seen what wide open throttle does to a brushless setup without a load. I now have a 1512 1D on the way for a 4s setup, and will reserve the 1527 for another project. Can anyone say 5th scale brushless.
