sikeston34m
sikeston34m's Avatar
01.01.2008, 10:18 PM
You could probably go down to an 18t or a 20t pinion on the 40t spur.
I know the 22t mod 1 pinion I have will work with the 36t spur, but that's just about the limit.
Notice how much adjustment there is left in the motor mount slide?
A setup like this on a Mean lower kv inrunner would be awesome also, for you guys that are looking for tougher ways to gear up.
01.01.2008, 10:32 PM
Good to hear, I will try the 2826/12 on 5s with 40/22 gearing. Can't wait for traxxas to bring out the 2 speed tranny.
sikeston34m
01.02.2008, 07:55 PM
Hey Linc,
Look what the UPS truck just delivered.
01.02.2008, 10:24 PM
Hey Linc,
Sweet, I need to get you a pic of the 125b!
sikeston34m
01.02.2008, 10:36 PM
Yeah that makes three.
sikeston34m
01.03.2008, 01:58 AM
I took one of the new E maxx's apart tonight and discovered a few things about them.
Did you know?:
1. The new E maxx has larger inboard bearings on all 4 corners for the wheels?
2. The new E maxx uses Rubber sealed bearings everywhere?
3. The new E maxx has steel Wheel Hexes??!!
They really have done alot of improvements on this one
01.03.2008, 11:22 AM
Did you know?:
1. Yes
2. Yes
3. Yes (I've been studying the exploded views alot)....
I think it was a clever move by traxxas to use the same parts on the T & E, saves having different moulds for all the parts. I wonder if the T-maxx will get an update with the better diffs and a longer chassis, then it would use the same lower braces too.
