ridinbikes247
01.05.2008, 01:41 PM
here is how i have them if i run 2 batterys
i have 2 batterys that each connect into the Y..how do i know if its series or parrel ?
ridinbikes247
01.05.2008, 01:44 PM
here it is
Name:	battery hook ups jpeg.jpg
01.05.2008, 01:50 PM
Both red wires connect to each other correct? If so you have a parallel connector. This would give you 7.2v and 8400mah. You should run a series connector, like this:series adapter it will give you 14.4v at 4200mah and get the truggy going fast!
jhautz
jhautz's Avatar
01.05.2008, 01:54 PM
Not sure what you have there, but it looks like you have the packs wired in parellel.
http://scriptasylum.com/rc_speed/_wiring_bec.html
go here and choose the "2 series" wiring option. it will show you how the 2 packs should be wired to get the series connetion you are looking for.
This page should show you how to wire any way you want it.
to make it...
or break it...
Silent...But Deadly
ridinbikes247
01.05.2008, 02:05 PM
is this how i should do it ?
