01.06.2008, 03:30 PM
Welcome to the forums!
Yeah, the ESC is most probsbly toast. Before you go get another ESC, I would try to see if there was anything wrong that caused it. Maybe the motor leads were shorted? Maybe the motor is bad? What voltage were you running? If over 2s or 7 cells, were you using an external BEC or the internal ESC BEC?
IIRC, Castle will repair it for $50...
HomeGrown
HomeGrown's Avatar
01.06.2008, 03:33 PM
im running a DTX 4200 7V... i should go to their website i'll assume..lol..
BL Pede, Integy aluminum steering linkages, aluminum shock caps, RPM camber links.
Never Replace Always Upgrade!
