01.16.2008, 01:40 AM
You will most likely be best off with the 7l on 5sa123. Make sure that you run a 5s2p setup, 2 packs of 5s in parallel, as the 7xl can draw some juice, and a single 5s pack will drop alot of voltae trying to keep up.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
01.16.2008, 02:56 AM
what does 3-5s mean? Is this the range you will be running, or you don't know yet?
The 6xl would run far too hot on anything, even the 7xl gets too hot... the 8 or 9xl would be perfect. IMO
1986camaro
01.16.2008, 03:01 AM
yeah the 3-5 is my range.thanks
zeropointbug
Z-Pinch racer
01.16.2008, 03:04 AM
So is it 3, 4, and 5s packs that you will have? Or you will be purchasing a 3, 4, or a 5s pack for this setup?
Sorry for not understanding...
1986camaro
01.16.2008, 03:15 AM
yes 3-4-5 and i will be purchasing.
http://cgi.ebay.com/6pcs-U-Joint-Axl...QQcmdZViewItem
would those axles hold up to brushless
