jhautz
jhautz's Avatar
01.17.2008, 04:35 PM
I am assuming this is for a revo based on your name....
The reality is the motor is rated for 60,000 rpm, but running them at over 40,000 really effects the effiency and generates a ton of heat. If you are planning to get a neu motor, choose the voltage you are planning to run and select the Neu motor that will generate somewhere in the 35-40K rpm range on that voltage. That should gice you a nice reliable setup.
My personal recomendation would be to get the 1515/2.5 on 5s and call it a day. Trust me that setup will put a big grin on your face.
If you havent seen one of these setupos run on 6s be prepared. Its a TON of power. I bash my revo on 5s and can easily out accelerate and outrun my buddies LSP that has a Fully Moded Novarossi 28 in it. 6s just breaks parts in the drivetrain every time you run it ands will take a significant investment in the drivetrain to make it reilable.
to make it...
or break it...
Silent...But Deadly
neweuser
neweuser's Avatar
01.17.2008, 05:04 PM
Well put!
Revoman
01.17.2008, 05:42 PM
kool well put....ill probably do that combo then and stick with the 5s
Revoman
01.17.2008, 05:47 PM
what are your run times and top speed with that setup?
jhautz
jhautz's Avatar
01.17.2008, 07:13 PM
run times on the true rc 2s + 3s setup I run is easily a half hour while bashing, probably more. but to be honest with you I rarely run a pack straight thru on 8000mah. I ususally run smaller 5000mah or 4350mah packs as I like the weight of them better
to make it...
or break it...
Silent...But Deadly
