Serum
Serum's Avatar
01.20.2008, 04:40 AM
@john;
Two motors on 1 controller with both motors mechanically connected with the same gearing ratio works. It's not a matter of time; you simple need to center the motors into the same position before putting on the pinion. Centering them is quite simple. Apply a DC signal to two of the three wires, and the rotor jumps into position. Do the same with the other motor (same + and -) and both motors are positioned.
