jhautz
jhautz's Avatar
01.28.2008, 07:31 PM
In reality the MM update that was just released appears to make the MM a viable ESC for the Neu now. If you are planning only a 4s setup go with the Mamba max and the Castle Creations BEC and you should be solid with that setup. The MM is $135 and the CC BEC is $22 so for under 160 you have something reliable. I wouldnt mess with those other ESCs you listed. They are fine for those who want to experiment, but if you want something you can count on go with whats proven to be reliable IMO
to make it...
or break it...
Silent...But Deadly
kingiggy262
BL-Revo
01.28.2008, 07:53 PM
Ok then I think i will go with the MM and update it with the new firmware. Then I will perform the mod1 upgrades to keep the temperatures down.
Thanks guys! These forums are filled with great information!
