Mod Man
01.29.2008, 07:55 PM
Yup, again, I have never needed any adaptors to run my HV110. It just works! In fact, it is far less throttle position sensitive (for arming) than my MGM Com Pro ESC.
Yes, that 127 amps is burst. I have pulled over 100 amps for relatively extended periods of time, though (6 second runs). I run mine run after run back to back with no heat issues. I did put a fan on it when the weather got really hot. But, it didn't need it. It never got hotter than 130 degrees according to my Eagle Tree temp probe.
I cannot recommend the HV110 enough, especially for the price.
If you have any programming issues or questions about it, call CC and ask for Joe Ford. You can tell him I referred you to him. He gave me great info on setting up my ESC for top speed use.
HV ESCs are all that Nic Case will run. We have spoken for extended periods of time in numerous conversations about this very subject. He and I are both very hard on equipment and we have both had fantastic luck with them.
Oh, wait till you see his TS car for this season! ;)
Matt
