1986camaro
02.02.2008, 02:55 AM
would a feigao be better?
02.02.2008, 02:58 AM
An 8xl is a good motor, and proven to work well. I assume you will use a mm?
1986camaro
02.02.2008, 03:00 AM
yes as i says on the first post.
02.02.2008, 03:03 AM
Not paying attention, too much tequila!
Not much testing has been done on the hybid motors so far. If you want to blaze some trails buy one and tell us how it works!
If not buy an 8xl.
1986camaro
02.02.2008, 03:17 AM
do you think it would be worth it to try it out?
02.02.2008, 03:20 AM
That is up to you. Given the case length at 54mm it may be too short to make the torque and handle the load of the emaxx. What speeds were you looking to get?
1986camaro
02.02.2008, 03:26 AM
around 35 mph with something smooth and light and hopefully not have to worry about cogging. i mainly just putt around and hope that this would be stronger than a mm7700 which is what i am using now. i just hope that it would have some nice grunt but not insane speeds.
