02.02.2008, 03:20 AM
That is up to you. Given the case length at 54mm it may be too short to make the torque and handle the load of the emaxx. What speeds were you looking to get?
1986camaro
02.02.2008, 03:26 AM
around 35 mph with something smooth and light and hopefully not have to worry about cogging. i mainly just putt around and hope that this would be stronger than a mm7700 which is what i am using now. i just hope that it would have some nice grunt but not insane speeds.
02.02.2008, 03:32 AM
I would say that it should be fine at 35mph, and a big step up from the 7700.
1986camaro
02.02.2008, 03:34 AM
cool! Thanks for the help.
No problem, have fun!
1986camaro
02.02.2008, 03:47 AM
Thanks, i don't use connectors i directly solder the wires from the motor to the esc does that make a difference?
1986camaro
02.02.2008, 01:29 PM
does weight matter with the torque of the motors?
