1986camaro
02.02.2008, 03:26 AM
around 35 mph with something smooth and light and hopefully not have to worry about cogging. i mainly just putt around and hope that this would be stronger than a mm7700 which is what i am using now. i just hope that it would have some nice grunt but not insane speeds.
02.02.2008, 03:32 AM
I would say that it should be fine at 35mph, and a big step up from the 7700.
1986camaro
02.02.2008, 03:34 AM
cool! Thanks for the help.
No problem, have fun!
1986camaro
02.02.2008, 03:47 AM
Thanks, i don't use connectors i directly solder the wires from the motor to the esc does that make a difference?
1986camaro
02.02.2008, 01:29 PM
does weight matter with the torque of the motors?
02.02.2008, 02:25 PM
Direct soldering is a good idea, it eliminates the connectors, which can cause problems.
If you have a motor that is undersized for the weight of the truck it will have to work too hard and will get quite hot. Generally a larger motor will stay cooler longer.
