Cartwheels
02.04.2008, 01:37 AM
Have you tried other radios too. I'm using a spektrum and when you blip the throttle it will occasionally lock the motor for a split second. Seems very harsh on the drive train. I thought maybe it was interference so I moved my radio further away. I tried it on the bench, but it seems like it is still going to do it.
hobbimaster
02.04.2008, 09:11 AM
Mine too was doing this, But strangely enough mine started acting up when I stiffend the springs. It would wheelie very hard, and it seems like when I'd briefly let off the throttle to get the front end down it would momentarily lockup. I went back to softer springs and behold, it stopped doing this. Very weird indeed. I'm sure this is only a sympton of the real problem, but sure did stop. I too run a spektrum system.
