azjc
02.04.2008, 07:31 PM
Originally Posted by skellyo View Post
The only issue with the 5mm shaft is getting 5mm bore pinions in 32P and then having to swap the spur over to a 32P spur...or buying Mod1 pinions and a Mod1 spur. It's not anything to stop you from buying a Neu, just realize you can't just drop it in without pricey pinions and swapping the spur.
thanx for the info, I went looking on the online store and I found the pinions but not the spurs, do you have a link for them?
I , do like the Neu motor, would there be any problems with the MM ESC, and would I need anything extra to mount the motor
